Polyurethane vs rubber
mavtricks71
az
mike
What is everybody's opinion on Front leaf springs ....I bought 8 inch springs for the lift. Now should I do rubber or polyurethane bushings?
Rusty Nail
Rusty
350sbc
Polyurethane.
OE manufacturers continue to use rubber because of costs and NVH (noise, vibration, harshness) but is very compliant during spirited driving causing poor handling and like your tires, they wear out. Heat, harsh fluids and UV rays will dry out, crack and rot rubber causing vital suspension and drivetrain components to function poorly. Some OE replacement parts use lesser quality grade rubber which may wear or fail quicker than the OE factory rubber. Polyurethane bushings and mounts are resistant to harsh fluids and do not dry out, rot or crack.
bluex
Spartanburg SC
C15
Get the black poly bushings, they are graphite impregnated (at least energy suspensions are) and will be less prone to squeaking later on. The red ones may look cool but they are the ones that generally need relubed every 6 months to avoid noise issues. I have had the black ones on my truck for probably 4 years or so without a single peep out of them and I only lubed them when they were installed.
Dougnsalem
I'll say rubber, since no one else has. Non conformists, unite! Lol
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
Keep in mind, not all black poly from ENergy Suspension has graphite in it. I wanna say @skysurfer called them for clarification and it was only on heavy duty truck bushings that have it.
True. For the vast majority of ES bushings its the same compound with different coloring mixed in. I tried to nail down what percentage of their products have graphite in them and the ES rep was struggling to come up with a number so I said "10 percent?"
"No, much less."
"5 percent?"
"Less than that."
"Anything for 1/2 or 3/4 ton pickups?"
"Nope, not at all."
FenderBanger
