Please Help
ramon Garcia
Connecticut
ramon
gmc
8cycl
I own a 1986 GMC C20 pickup Im trying to save. It was dads' 1st new truck. It wont drive pass 30mph seems like its struggling. I checked transmission oil and it had none so I put 2 1/2 quarts but still same issue. Any advise out there I know nothing about mechanics.
AKguy
Alaska
Randy
K30 Crew Cab Silverado
Welcome. Is the emergency brake on? I assume it is an automatic and my first place to look would be the transmission if the engine RPM’s are normal. May be bad pump, etc.
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
Sounds like the trans is fried, running it with no fluid only made it worse.
If its just not shifting out of first, could be the vaccum modulator
Could also be rear brakes are stuck from sitting too long. Try taking off the drums and cleaning everything. Get them moving again.
SirRobyn0
You have given very little information about how the truck is behaving. And I say this not meaning to offend you but it appears that you may not have a lot of experience fixing cars, which is fine we can walk you though a lot of stuff, but we got to know what's happening. Could the transmission be having a problem, I agree it's possible but I can't say based on low fluid that, that is what has happened. He could be starving for fuel, and I agree with the others that have said brakes sticking are possible.
Now some questions:
About the transmission, did you check the fluid with the engine running and the shift lever in park? or did you check it with the engine shut off? These transmissions should be checked with the engine running, if checked with the engine turned off you'd now have it over filled.
Is it in overdrive transmission? Or three speed transmission?
Can you take a video of the truck driving and what happens when it starts to struggle? If you have a tach in the truck point the camera at that so we can see the RPM's and hear the sounds it's making. Even better if the tach and speedo are close enough to capture them both in the video.
mick84
