Pilot Bearing
Ronno6
South Mississippi
Ron
The 350 which I purchased has a needle pilot bearing in the crank.
Any chance this is reusable?
The time is now to replace it, I guess.
I've seen some neat tricks to remove pilot bearings, like grease or wet paper pieces
to exert hydraulic pressure to remove the bearings.
Should these work on the needle type bearings?
yevgenievich
Place
Name
Year
Model
Size
Part stores rent a puller. Replace the bearing. For higher performance application some would recommend a bronze bushing instead
K201979
Winona, missouri
Hippie
350ci
Not sure if it works on a needle bearing, but ive used bread to get a bushing out. Worked like a charm. Not as messy as grease.
Ronno6
South Mississippi
Ron
Yup. I've seen bread and paper soaked in water to keep the water from just squirting out.
The truck it came out of was automatic, but it was not the original engine........
No serial # (S/N on a sticker...) so I couldn't track it to its roots........
K201979
Winona, missouri
Hippie
350ci
The bread doesnt have to be wet. Probly less messy than wet paper too. Just break off pieces and beat them in there till the bushing falls out. Then dig the resulting "biscuit" out.
jash1990
