PCV swap- great results!
SquareRoot
Ya, title sounds odd but...
I've got my Vortec 350 running great but still had one part I needed to swap; the stock pcv for the Wagner dual-flo, billet aluminum piece. Yes, I spent $125 on a pcv so get over it.
With a warm engine at idle, I had 15 inches of vacuum and a slight lope. I swapped the valve and adjusted according to the instructions. The idle went up 400 rpm. I brought it back down and she runs exceptionally smooth without lope at 19 inches vacuum. Noticeably improved throttle response.
ME Wagner- check it out.
Made a believer out of me.
http://mewagner.com/?p=444
donnieray
Talks to dogs and trucks.
Roanoke Rapids NC
Donnie
86 C10, 84 K10 MM7 NP833 option truck, 85 K10.
350,355;350.
Interesting, I wonder if it would be helpful on older smallblocks?
yevgenievich
Place
Name
Year
Model
Size
As alternative, Purolator PV774 is supposed to be setup for low vacuum engines(non factory cam)
SquareRoot
I wouldn't consider 16 inches low. Unless you have a bone stock engine, "close" is as good as you'll get- if they still sell 35 year old parts.
I think the big benefit is the dual circuit rather than the all or nothing approach.
Here's a good read on it.
https://www.hemmings.com/blog/article/let-it-out/
souixchef2
