Parking Brake Strut Spring
Arkansas
Cody
Anybody know where to find a new spring for the parking brake bar?? Or an alternative that will work? There is a rectangular spring with a loop off the side that goes over the flat bar with slotted ends (goes on topside between shoes). I took the drum off on the drivers side and that bar was loose just fell out on the ground; put it back together with the existing spring which looks to be about half of its original length (this spring doesn't come in the hardware kits). The passenger side spring looked like it should and bar was in place.. After driving for just a few miles, the bar on the drivers side is loose again and rattling around inside the drum.. I've been to several parts stores and cannot find this spring.
The last two pics show the good spring on the passenger side...
RustyPile
Left on own accord
Elkhart, TX
Nick
1983 GMC
350 SBC
I hope I'm not too late to come in on this post.. First you have the spring installed on the wrong end of the bar. That spring goes on the "leading edge" toward the front of the bar.. The spring is not there to keep the bar in place, just to keep it from rattling.. The reason it's falling out is because you don't have the shoes adjusted properly.. They're too far away from the drum and when you apply the brakes, the wheel cylinders have to push the shoes so far that the bar and shoes separate.. Adjust the shoes so that they just start to drag on the drum and you shouldn't have to constantly put the bar back in place....
Dons79C10
