Causingdefiance
- Jan 16, 2015
- Colorado
- Daniel
- K2500
The other day I noticed the instrument cluster lights weren't working, so I checked the fuses all good there, then I noticed I had no running lights either. Then I noticed no brake lights or reverse lights. Only blinkers/hazards/headlights were working.So I started ripping everything apart. Steering coloumn wires looked good so I moved to the fuse box.noticed the insulation on a few wires were gone so I replaced them fixed all wiring and put it all back together. And still nothing. So I moved to the fire wall noticed a blown fuse replaced that and still nothing. Then I ran a hot wire straight to the fuse box cause I wasn't getting power to the light fuse, when I connected it and something went wrong, now the only lights I have now is the head lights and front right blinker everything else went out. I can't seem to figure this out, any thoughts? I have power to everything in the fuse box but the light fuse. And running that hot wire seemed to make things worst.
