On door weather stripping
BigPoser
Bakersfield, CA
Brandon
Cheyenne Super 10
I have some weather stripping ready to install, but can't see any place for it to actually go. There are no holes to mount the one end to and I can't find any pics showing proper placement.
Anyone have any pics, or tips?
Brandon
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
Are you talking about the inner/outer stripping at the bottom of the window glass? If so once you take the old out you'll see slots the clips clip to. I used a screwdriver to carefully pry the outer seal. You have to roll the window down first and you may want to wrap part of the screwdriver with electrical tape to protect your paint.
BigPoser
Bakersfield, CA
Brandon
Cheyenne Super 10
No sir, I'm referring to the one that runs on top of the door that seals to the upper door jam. I have re pop doors (which I am regretting) and they don't have any holes for screws anywhere.
crazy4offroad
Curt
K-10
350/SM465/NP205
The door jamb seal on mine attaches to the cab. There is a metal flange all the way around and the seal has a channel that you press on the flange. A pic would be helpful of what you're talking about because I've never seen the seal attach with screws.
chengny
You're talking about this seal, right Brandon?
If so, this seal doesn't use any type of fastener to install. It just snaps over the raised ridge that runs around the perimeter of the door frame:
There are some applications where the seal - rather than being mounted on the door frame - is mounted directly onto the door itself. I don't believe that this was an option in 1973 - but be advised, I know next to nothing about C/K trucks of that era.
BigPoser
Bakersfield, CA
Brandon
Cheyenne Super 10
Ha, no sir. I'm talking about the seals that go on the doors themselves. When ordering all the rubber I found that one and got it. My truck doesn't have rain rails above the door so I figured that it would help in keeping unwanted water and wind out.
Georgeb
Wisconsin
George
K10 Burb Z71
Please post some pics.
chengny
Don5
West Virginia
Don
k15
I just looked for my 2014 LMC catalog to see if it was in there. I couldn't find it, I think it is in the garage, so I looked at my old 2004 edition. That one shows a door weatherstrip for 1979 to 1981 models. It is fastened by two screws and held with adhesive in the middle. The screws are fastened around the bottom level of the window. Is this what you are talking about Brandon? How long is this weatherstrip?
EDIT- It is the one Chengny posted a pic of?
BigPoser
Bakersfield, CA
Brandon
Cheyenne Super 10
Yup you are talking about the right one. Item #2
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=21
It's listed as a 79-81, but it should work on a 73 right?
BigPoser
Bakersfield, CA
Brandon
Cheyenne Super 10
So does anyone have these on their doors?
Now that I'm driving my truck again, I get a lot of wind noise through the door and I can't stand it. Hoping to get these installed and kill the wind noise.
SlickGTP
Houston, TX
I think mine just have some sort of adhesive holding them on, but I can verify when I get home.
Yes, it came on Silverado (or Cheyenne Super) models and a lot of mine have had it, even the '88 Burb, which is a self-adhesive type. My '79 has it too, but I don't remember if it has screws at the ends. I don't think it does.
SlickGTP
Houston, TX
Yeah, just verified that mine are/were held on with just an adhesive...
cpender
