Oil
Mango
JacksonWyoming
Gil
Hey All
What oil are you using? I have a 89 With over 200,000 mile and running 10W-30 Conventional. Some blue smoke at cold start ups, Valve Seals and small drips on the bell housing rear main seal?
Would you stare using High Mileage synthetic Blend or straight Synthetic Oil ?
I done some research and Synthetic causes leaks from removing sludge around gaskets and that it restores gaskets WTF
gmbellew
Kansas city
glen
suburban 1500
Not much you can do about any of that, save for replacing gaskets or maybe some Bar’s rear main seal repair (I’ve had good luck on short term with it). I run 5w-30 still with 280k on my 90 burb. Been using the valvoline restore and protect for about a year now.
ali_c20
Austria
Alexander
C20, K5
Oil is not going to fix mechanical issues...I would run what was in before and fix when smoke and drip starts getting worse.
NLD79K10
Netherlands
Lars
I just stick to the specified oil for the engine, nothing fancy like a "high-mileage" oil or anything like that.
Seeing as it gets replaced every 12 months because I don't make 7500 miles in it between changes, I throw in a decent mineral 10W40 oil with high zinc content for the lifters and a good quality filter and call it quits.
Changing to a different oil isn't going to fix your blue smoke or oil leaks, that requires fixing the root cause rather than trying to hide the symptoms.
75gmck25
Northern Virginia
Bruce
Mobil still makes at least one weight of high ZDDP synthetic oil, and they used to stock it in 5 quart jugs at Walmart. Cheapest solution I found for a flat tappet cam engine.
I have now installed a roller cam, so I have not checked lately for the high ZDDP oil.
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
I run 10w30 valvoline conventional. You're running conventional, stick with it
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Do some investigating, whatever oil make sure it has low levels of calcium detergent. The calcium detergent washes the DZZP off of the cam. API SP oils have lower levels of calcium detergent. All modern oils still have 60s level DZZP
Interesting article. I run the Valvoline Restore & Protect 5W30 in all my vehicles now - if they would offer 10W30 in the US ( Mexico gets it -? ) I would run that in Goldie. Still hoping for the reduced oil burn in Goldie. We shall see ...
:cool:
gmbellew
Kansas city
glen
suburban 1500
:cool:
I feel like it has helped some with my consumption. Currently I am down 1/2 a qt every 1k miles. But I changed plugs this spring and compare photos of the plugs to ones I took 2 yrs prior and there was A LOT less oil and sludgy stuff on the plugs past their shoulder on all cylinders except for no2 that showed no change. Most went from wet and sludgy to dry. That was after about a year of RnP use. Will see what the plugs look like the spring after next when they are due for a change again.
Mango
JacksonWyoming
Gil
Using Napa 10w-30 should I add AZDDP additaves more Zinc?
How mUch DZZP is in it's as is? Is it a high calcium detergent oil? What is the API rating?
Mango
JacksonWyoming
Gil
It has 650 to 880 ppm of zinc and API rating SP and SQ
Finkaire
Finkaire
California
Loren
Silverado c10
Running straight 30w, I’m in California. Hard to find in stores, crazy!
Terlingueno
Far West Texas
Skeeter
K20 Suburban
350/SM465
I use Valvoline VR1 10w30 in my truck.
It has no API rating
Calcium detergent is still kind of high. I'd run it if that's what I had but I'd switch to Mobile classic.The VR1 looks good also. The calcium detergent washes the DZZP off.
Shifted
