Oil Sample low Viscosity
Mango
JacksonWyoming
Gil
Hey All
My 89 burb 350 197898 miles oil samples coming back with lower and lower oil viscosity?
No coolant, fuel in oil sample?
New intake manifold Gaskets about 5600 miles ago
Burns oil only at start up valve seals
Could it be O2 sensor does seem to run rich $
How to check O2 sensor it is the original
Thanks
Hey All
Thanks
I hate to just replace O2 sensors without testing them. But 35+ year O2 sensor,just get new one. While your old one is out put a volt meter on it heat it with a propane torch.watch your meter, voltage should be between .1-.9 volt and vary with heat. Another thing you could do is get the O2 hot,drive around a while. Disconnect the O2 sensor,put a meter on it,let the voltage get stable. Now create a vacuum leak,watch your meter. Spray carb cleaner in the intake,watch your meter. Let things stabilize. It should read .1 full lean .9 full rich .5 just right.
fast 99
Spokane, Washington
200k is a lot of miles. Could just be leaking by the rings. Perform a leak down.
Mango
JacksonWyoming
Gil
New o2 sensor runs better and mileage is up slightly
A mechanic suggested to check injectors after turning the engine off and see if they are still pushing out fuel
Is this a thing?
Is this a thing?
Absolutely,with time injectors can develop leaks just like your kitchen faucet. Turn them off but they still leak a little,sometimes a lot. You should also check your spray pattern.
Sad Sack
Nebraska
Goober
C15
Hey All
Thanks
Just curious, so if ya pull the oil dipstick out and sniff it on the end, do you smell gas?
gmbellew
Kansas city
glen
suburban 1500
Is this a thing?
easiest way to check for leaky injectors is sometime on a cold engine put some paper towels under them, turn key to ON for 3 sec to let the fuel pump prime, key back to OFF. then check the paper towels for fuel.
Mango
JacksonWyoming
Gil
Hello
Oil does not smell like Gas the guys in the shop could not smell gas!
cadillac_al
Maine
Alan
Is this quality oil or economy oil?
Mango
JacksonWyoming
Gil
NAPA 10W-30 made by Valvoline
cadillac_al
Maine
Alan
I tried some Carquest oil in my Cadillac Deville. It was on sale. The oil light came on at idle on like the 2nd day. I ran it for a week or so and then I drained it and put some name brand oil in it and the oil light didn't come on. I don't really trust the parts store brands. Your low viscosity is probably as simple as that.
The Right side of Washington
How do you know the viscosity is lower than it should be? What are the actual vs specified values at how many miles/engine hours.
You’ve given no frame of reference.
What was the symptom that prompted you to do an oil sample. That’s an unusual test on a 200k mile 35 year old run of the mill motor.
Old motor runs good, no issues? I’d throw some thicker oil at it if you think the oil pressure is low or the oil is thin….
Moderator
Sounds like your Deville has very borderline OK oil pressure.
cadillac_al
Maine
Alan
Probably so, it didn't like cheap oil. That was the only time the oil light came on when I owned it.
hauto85
