oil pressure gauge unit?
Bman
Oliver springs,tn
Ben
GMC sierra classic 1500
5.0/ 305 LE9
Okay so ive looked into this and im confused.
I have the full gauge cluster. Oil, temp, volts, clock. and all works but the oil which is pegged at 60psi.
I looked into getting a new sending unit for the motor (which is out of a g20 van) and i don't know weather the unit on the motor was for the idiot light or for the gauge.
Which is which is basically what im asking.
Also. a bit unrelated to the oil gauge. Engine has a knock sensor, but its broke and disconnected. the truck has a connector for one. should i bother putting a new one in? or leave it unhooked?
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
The engine shouldn't matter that much, the thing that matters most is that you get the right sending unit for the year that your cluster is.
Bman
Oliver springs,tn
Ben
5.0/ 305 LE9
well as long as the clustor is original to the truck. its an 1983. and thats what im asking. what sending unit in that year was for the oil gauge and not the light.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
Im pretty sure that the oil light sender is above the oil filter and it has two spade connectors, and the oil sending unit has a single spade connector and is located next to the distributor on the drivers side. But I think there are two different sending units you can get for that year I believe the resistances are different.
Dennis Blom
