Oil leak
wdbill
Phoenix
Walt
K20 suburban
I have a 1985 k20 suburban. Just recently got a new motor for it. Still stayed with the 350 but put in a newer version with a roller cam. I'm noticing some oil on the water pump, alternator and also on the air cleaner. I been trying to see where it is coming from. It isn't leaking on the ground. It happens when I'm driving. Any ideas please let me know thanks
Turbo4whl
Downingtown, PA
Wayne
A place to look, engine oil cooler in front of the radiator. Trans cooler in the radiator. Sounds like maybe oil blowing back on the front of the engine.
wdbill
Phoenix
Walt
K20 suburban
It has a brand new oil cooler I'll take a look at it that might have something to do with it
Look for oil stripes on the fender wells and bottom side of the hood. If you have stripes the oil is being slung, either by the fan or the harmonic balancer. I'd check the front crank seal real good.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Possible power steering pump as well.
wdbill
Phoenix
Walt
K20 suburban
Distributor gasket.
It has one...right? You put it there?
Yes it has one. But the is in front of the motor and the distributor is in the back of the motor. I been looking at the intake manifold end seals also.
Rickf
Grafton NH
1974, 1954 & a 1937
Isn't there a dye and black light that can be used?
wdbill
Phoenix
Walt
K20 suburban
There is a hole on the bottom of the block next to your oil pan below the fuel pump. Any ideas what this could be.
wdbill
Phoenix
Walt
K20 suburban
I did a search and found leak detection dye. GM even makes it! Found it on Amazon. Dye glasses and UV light for $28.00 and I can use the light to hunt for scorpions in the summer
Dave M
Banned
Australia
Dave
Oil gallery plug
I have a U.V. dye kit . I almost never need it clean everything real good and check for your leak daily. Use a flashlight. The U.V. dye makes the oil easier to see, but your still going to see U.V. dyed oil everywhere.
wdbill
Phoenix
Walt
K20 suburban
Oil gallery plug
Is it possible for oil to leak from the oil gallery plug?
Found a better picture
wdbill
Phoenix
Walt
K20 suburban
Dave M
Banned
Australia
Dave
No that isn't an oil gallery. I had issues with sance-`
Dons79C10
