- Aug 18, 2010
- North East Texas
- Shawn
- 1982 & 1985
- K10 Extra Cab w/ Proper SWB, & 85 K5 Blazer
- 454 BBC, & 383 Stroker
Ok, I have had an oil leak now for a couple of weeks, and I still can't find were it is coming from, I have
1) changed out the valve cover gaskets,
2) went under it today to check oil pan gasket, and to see if the rear main is leaking. Pan and torq converter were dry.
3) checked oil pressure line and connections, took it apart cleaned them and put it back together.
I'm wondering if it could be the valve cover gaskets I used, they were the rubber gasket with the metal center, so I'm going to change them out again with the good old cork.
I'm wondering if it could be the high volume oil pump causing to much pressure in the motor, and all I have is a PCV valve to vent the motor.
The fire wall and back of the motor is not wet, so I don't think it is intake manifold gaskets.
Anyone have any suggestion, because it is becoming a big pain in the ass.
