NO Spark...... TBI 88 GMC 5.7 350
mhelms83
GA
Suburban V1500
350 5.7 TBI
no pin in the "D" port :( yeah im getting fuel, but still no spark.
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
Your ECM is good then, and your ignition module is providing a reference pulse. can you take a pic of the top of your distributor for me?
mhelms83
GA
Suburban V1500
350 5.7 TBI
here it is.
Jims86
Patterson,Ca
5.7 TBI
Ok, how about the top of the cap, and inside if possible?
It may be a crap shoot, but since you're running out of options here....
Have you by chance cranked the motor with the dizzy cap off to make sure you don't have a broken dizzy shaft, or dizy gear or gear pin??? I'd do that. If the dizzy isn't getting dizzy, you get no spark to the plugs.
Jims86
Patterson,Ca
5.7 TBI
the injectors wouldnt fire....Im wondering if he has a plug wire on the coil terminal of his cap, and vise versa.
Post some pics of the engine with the air cleaner off too...the more eyes peering in there, the better. Are you comfortable with taking the ECM out and doing some electrical tests with a meter? There is one wire that I am suspiciouse of, considering the ignition is the only problem.
mhelms83
GA
Suburban V1500
350 5.7 TBI
Yes the distributor is spinning. the dist. cap is new here's an inside view. Yeah im fine with pulling the ECM and doing some tests. pic #2: 1st off, i know my plug wires are a mess right now! The relay, just above the trans dipstick, i heard a "pop" noise come from that. There's no other wires to the dist. cap besides the coil and plug wires. Pic #3. I think this is the oil pressure sensor? I unplugged it and its filled with oil. Is this normal?
I don't know if i mentioned this before, when the truck broke down i was going about 35mph and it backfired 1x and sputtered a little, then nothing.... dont know if that will help
Jims86
Patterson,Ca
5.7 TBI
Holy ****!!!!!!!!!!!!!!
that firing order looks way off to me. Are you sure your distributor is in correctly? we have to be sure its correct before you can take it to a shop...it is GMSB regulations!
What do ya say we take it out, and start over!? and then re run those wires?
Did you remove the distributor from the engine when you replaced everything?...We are going to stick with you on this, bud!
mhelms83
GA
Suburban V1500
350 5.7 TBI
if you need more pics please let me know. and @Jims86 and @hotrodPC, you guys rock! i cant tell you how much i appreciate all the help. times are tough and i really dont have the money to put her in the shop and so far you've helped me keep her out so far. She will roar again...i promise you that.
mhelms83
GA
Suburban V1500
350 5.7 TBI
ok, i did remove the dist to replace the pick-up coil because it was bad. ill pull it out and make sure to put it back right in the morning. so what about that "oil pressure sensor?" and the relay on the firewall next to the trans dipstick? would either of those cause my problem?
Jims86
Patterson,Ca
5.7 TBI
Did you remove the distributor at all when you replaced the parts, if not, we can skip that part....maybe.
Jims86
Patterson,Ca
5.7 TBI
woops! we need a traffic light in here! LoL
Jims86
Patterson,Ca
5.7 TBI
Nope. Are you familiar with finding top dead center? I dont know what your mechanical experience is, and i dont mean to make you feel like an idiot in any way, but you are willing to make the effort, which is enough to get this figured out...even cross country.
mhelms83
GA
Suburban V1500
350 5.7 TBI
yeah I think so, using the mark on the flywheel? like you're adjusting the timing?
Jims86
Patterson,Ca
5.7 TBI
Ok,right, BUT...(unplug the coil, and take the plugs off of both injectors)you need to take spark plug #1 out, put your finger in the hole, and have somebody bump the starter, untill your finger gets blown out.
then line up the timing mark to 0degrees on the timing scale by hand...it shouldnt be too far from it at this point.
You are now at top dead center.
If you go by the mark only, there is a 50% chance that the cylinder is on its exhaust stroke...dont want that. The crank turns twice for each cylinder to do its job.(1/2 a rev equals 1 stroke)
when you re set the distributor, the rotor should be pointing at #1, at around the 5 O'clock position.
MikeD
