- Feb 26, 2023
- Central Arizona
- Paul
- C2500
Good Morning Everyone
I have a dilemma going on with my oil pressure. My 84 with a 350 ha been running great, everything normal, but after I parked it at work Sunday morning and then came out and started it, to go home, I had no oil pressure. No knock or running rough. I rapped on the gauge bezel, no movement. It gas a small oil leak, so I added a bit of oil. No change. I left it running to go back in the shop and when I came back out, it sounded like it was starting to knock so I immediately shut it down and called a friend. I thought the oil pump so ordered one from O'Reilly's. When I dropped the pan, there's nothing in it. Only thing I notice is the nylon coupler for the pump shaft has a full length crack. . I'll probably pull the distributor tidy to see if something on it has broke. Adding some pics of the coupler and the bottom end of the engine. Any other things I might look for?
