No ignition power
84K5offroad
Merced
GMC Jimmy High Sierra
I was driving down the road and the volt meter jumped to 18.6, the vehicle back fired and died. Now I have no power to the windows, door locks, ignition, or radio. It doesn’t even try to turn over. Batteries are good, I removed the fusible links from the starter and nothing. Pulled the ignition module and there’s no power going to it. Now I’m lost and I have no idea. Anyone have any suggest?
chengny
Have you checked the fusible link up near the junction block mounted to the FW. I would do that next. In addition to those components you mention that link also feeds a lot of other things via the ignition switch.
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
:welcome:
84K5offroad
Merced
Yes I checked that and both sides have power.
Cuba
Likes to work alone in her woman cave
Philly, PA USA
Cuba
S10 Blazer
4.3ltr TBI
I would check ignition switch on the column make sure you have power to it... or the interior fuse box, but only some fuses will have power unless key is on, engine off. Even then not all all will have power, but most should. That would tell ya if ignition switch is somewhat working.
If not, start looking towards switch
84K5offroad
Merced
I have no power going to the ignition switch. I pull it last night and tested it.
chengny
Might be at the main bulkhead connector.
X2
Your connector won't look exactly like this (87), but the stab connections for the power feeds will be in the same bays as shown. Top row - most inboard bay and 4th row down - middle bay:
Another member recently found this situation:
h
84K5offroad
Merced
There’s no picture
Cuba
Philly, PA USA
Cuba
S10 Blazer
4.3ltr TBI
X2
h
Wow, that's an odd spot for failure. How about that!
Cuba
Philly, PA USA
Cuba
S10 Blazer
4.3ltr TBI
There’s no picture
On chengny's post. I see both. Maybe use browser instead. Tapatalk sucks, IMO
chengny
There’s no picture
How about these:
84K5offroad
Merced
Mine look clean.
Cuba
Philly, PA USA
Cuba
S10 Blazer
4.3ltr TBI
So refer to the schematic link I posted. Print out the ones you need because I think it makes it easier to read, and you can write on them, checking off what & where you checked
chengny
Mine look clean.
Don't go by how they look. Check for power with a meter. The probe should be able push through the black gunk, fit into the gap and make contact with the crimped connection. If not, pierce the red leads with the probe - as close to the block as possible. Electrical wiring generally fails at the terminations. You should always see battery voltage.
Assuming you still have headlights, tail lights, horn & dome light - correct? Here is the diagram for the circuits supplied by the RED 2 lead that transits the bulkhead connection block in the upper inboard bay. Unfortunately it is becoming apparent that it isn't the one you're having a problem with. The branch that serves the two ignition switch terminals (BAT2 & BAT3) is the lower one - 4th row down middle bay.
Pugs Speed Shop
