chevyteeruk
- Oct 18, 2014
- cheesehead state
- mark
- silverado v20
1987 chevy Silverado v20
I have no dash lights.. running lights... headlights... dome light... or cargo lamp... turn signals and brake lights work.
-fuses are good
-headlight switch is new
-connector for headlight switch seems fine plastic isn't melted
-no trailer wiring mess in back
-I am getting power to the switch at orange and red wire... but if I pull switch the volts at both wires go to 0 right away and nothing happens
-grounds are good on the core support for headlight wiring
- i ran a hot wire to a headlight to see if they worked when supplied power manually.. both came on running lights did not... and the brights indicator on dash had the blue bubble glow, but when i hit the switch on steering column to switch from brights to dims nothing happened
-there is 2 wires i traced from switch leading to where radio used to be, a orange and a brown, orange has volts but brown doesn't and if i pull switch theres no volts at orange.
-with switch pulled none of the other wires on plug read any volts either.
- fuse block was good on the back no corroded or frayed wires...
stumped any ideas???
-fuses are good
