no fuel spray
pete g
south florida,usa
peter
astro van
4.3l
1990 astro van 4.3l vinz tbi changed two injectors, map, iac. noid light pulsing, injectors clicking. fuel pressure at diconnected fuel input line 15psi. need help please.
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
I've had this problem once and it ended up being a bad pickup coil inside distributor. Not saying that's your problem but maybe worth looking into.
Check fuel pressure again maybe with a different gauge. If injectors are clicking and void light is flashing. It is a fuel related problem if you have fuel pressure and volume to the throttle body the problem is on the throttle body. Sounds like something is plugged.
pete g
south florida,usa
peter
astro van
4.3l
do you need to check fuel pressure with the fuel lines connected? can a defective pressure regulator cause this?
I'd put a tee in the line and check it there.
fast 99
Spokane, Washington
On early TBI vehicles they make a log with fuel pressure test port that can be inserted where the fuel filter is. However, if you have 15psi, noid flash and no fuel pulse either line is crushed/plugged or there is an issue inside the TBI unit as Ricko suggested. Suppose the larger line could be loosened at the TBI unit to check for fuel but disable ingition first.
pete g
south florida,usa
peter
astro van
4.3l
ordered another fuel pressure gauge. will reply. only thing left in tbi unit is press reg.
pete g
south florida,usa
peter
astro van
4.3l
need to get accurate fuel pressure value.
If you are deadheading the pump and only have 15psi you have a bad pump,a plugged sock a plugged line or similiar
pete g
south florida,usa
peter
astro van
4.3l
deadhead? what socket? whats the solution? fuel presssure for this van is 9-13psi. oh, sock in fuel pump,ok
pete g
south florida,usa
peter
astro van
4.3l
checked fuel pressure with new gauge. gauge shows no fuel pressure. changed fuel filter, same no pressure. looks like pump.
squaredeal91
Greg bush
1991 SB
Check fuses and fuel pump relay for power in and out with ignition on.
Dead head is where you test the pressure right at the fuel line from the pump,not allowing it to also pass through the FPR and throttle body. Remember when I said I'd put a tee in and check pressure there,that would not be dead head. Dead head pressure will be higher and 15 psi deadhead is not enough for TBI
legozombie
Colorado
A
5.7 350 v8
I put this together based off Lars' version at the corvette forums. Put it between the carb inlet and end of the fuel line that connects to the carb. Tailor it to your needs ofc. This checks the head pressure while closed and you can see the pressure while the car is running.
Ah didn't realize this was TBI. My bad. Maybe this will help, maybe it won't. I would also recommend you get an electronic pump if you don't. Physics says you can probably put two Edelbrock 17301s in series to get the desired pressure and wire them up in series so they're getting the same current......I'll shut up now
pete g
south florida,usa
peter
astro van
4.3l
the pump is getting power. new fuel filter. if fuel pump, how hard to change?
Jeremy89
