new truck need help!!!
Ireland87
indiana
jacob
k10/v10
305 sbc
i just bought a 1987 k10 or v10 short bed fleetside as my new project truck. was looking at the suspension and saw that the rear was sitting on 3/1 leaf springs with a 3 inch lift block but the front suspension is completely stock and truck is sitting at stock ride height. i am wanting to do either a 4 inch or a 6 inch suspension lift on the truck but the rear leaf spring is causing a headache. i think if i got rid of the 3 inch block and got a lets say 5/1 or 6/1 rear leaf spring the truck would still sit at stock ride height instead of having the 3/1 which i think would make it sit lower than the 5/1. am i correct on my thinking? if im correct then i buy a 4inch rough county lift it would it only sit an inch higher since it has a 3inch block with smaller leafs.
Craig 85
Nashville, TN
454/TH-400/NP205
Are you looking at buying new oem springs or are you going to lift it immediately? If you're buying springs, I would just get the 4" lift springs. My '79 K15 short bed had the 6/1 set up.
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
The number of leaves in a leaf pack doesn't necessarily mean a difference in ride height. Ride height is dependent on spring rate and the spring arch. Higher spring rate means it takes more weight to compress the springs the same amount thus leading to a taller ride height, but will be left with a stiffer ride. Increase the spring arch will increase the spring rate a little, but it mainly decreases the sag in the spring pack.
If the 5/1 or 6/1 has leaves with the same thickness as your current leaf pack, you will have a slight increase in height, but will mainly be running a much stiffer suspension.
If you remove the current spring packs and blocks and add a 4" spring lift kit, then yes, you will only increase the rear height by 1".
Craig 85
Nashville, TN
454/TH-400/NP205
Do you think a PO took some leaves out? Possibly the factory over load which create most of the arch. I've never seen that few. The minimum Truck Spring lists is a 4/1.
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
Possible the PO removed a leaf or two to soften up the ride or allow for more flexing.. Maybe he also swapped the leaf pack out with one from a light duty truck? Did any of the C10's ever come with the 3/1 pack? What about suburbans or k5's?
Ireland87
indiana
jacob
k10/v10
305 sbc
I had a 81 c10 stepside and it came with 3/1 springs. And this k10 has the same springs which I wouldn’t think is correct. Im just confused on why the truck is sitting at stock height when the front suspension is stock and the rear has a 3inch block.
78C10BigTen
pennsylvannia
C10 BIG TEN
Here is a picture of my 78 c10 big ten factory leaves. Granted its not an 87 but itll give you a reference
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
Are you sure its sitting at stock height and doesn't actually have a set of lift springs in the front? Do the front springs have a negative(downwards)/flat or positive(upwards) arch to them? If its a positive arch, then you have a lifted front end. Negative would be stock springs.
My assumption is that the previous owner swapped the rear springs, or removed a leaf to soften up the rear end, but then installed the block to help retain height.
Pictures greatly help as well.
Ireland87
indiana
jacob
k10/v10
305 sbc
the front springs are slightly downward. so they should be stock correct?
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
Sounds like they are.
Got a picture of the rear end? How thick are the rear leaves?
Ireland87
indiana
jacob
k10/v10
305 sbc
no i dont have a pic at the moment. i can get one tomorrow tho. i dont think they are that thick but ill check tomorrow
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
No worries.
Thickness of the leaves allow us to compare whether your current pack is the same as a factory pack with leaves removed, or if its a different pack entirely for a lighter duty truck.
Gurn
