New Retrosounds radio won't even turn on? (also what is the grey wire?)
Challis350
Vancouver, BC
Nick
C2500
Hey guys
I've got a 1986 GMC C2500 and i've got the corresponding Retrosounds radio. All the speakers are in and i've attached the relevant wires to the speaker harness provided.
My problem is with the power harness.
On the retrosounds power harness I have black (ground), Yellow (12v constant) and red (12v accessory). The old radio wires, however, are yellow, black and grey. I've attached black to black, yellow to yellow (which lightly sparked!), and then grey to red, but the radio won't turn on.
Am i missing something obvious here? Pic below:
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Gray is dash lamps. If the new radio has a wire labeled illumination or dimmer, that’s the wire you want to trigger the radio to dim the display.
This is a pinout for a stock GM radio. Black is ground. Orange is constant power. Yellow is ignition power. Brown is taillight (used on some radios for bscklighting)
Hope that helps.
Challis350
Vancouver, BC
Nick
C2500
Thanks all.
The orange wire from the cigarette lighter worked perfectly when connected, and yes, I did blow a fuse in the process.
Case closed.
Finkaire
Finkaire
California
Loren
Silverado c10
I used the plug and play adapter from Crutchfield with no problem using the stock plug and speakers, like it a lot
TPISly-C10
Boucherville QC Canada
Sly
C-10 shortbox
LQ4 6.0L
Hey guys
black is GND-yellow ignition power and grey dimer light....you need orange constant positive to have it work ;)
Iamsoocluess
oregon
fabian
chevy
small block
Thanks all.
Case closed.
To clarify black to black, red to yellow and yellow to orange cigarette wire?
Randy and Easton
North Richland Hills, Texas
Randy
C-10 LWB
@Iamsoocluess what are you asking? I’m confused? If it’s stereo power we answered you in another post you made.
Yellow from truck is power, black from truck is ground and grey from truck is the back lighting for the radio.
johnalen76
