ryan.johnson
- Feb 23, 2014
- Texas
- Ryan
- c10 lwb
Just installed a 1406 on a performance eps 2701 intake after numerous problems.
I put in the off road needles and seats and adjusted the floats on the carb before I installed it and am running a holley fuel pressure regulator around 5 psi peak.
I'm idling around 850 park 650 drive and timing is about 8-9 btdc - unless my distributor is off a tooth as I just changed the esc system out for a hei.
starts pretty slowly and the distributor is disconnected from vacuum and carb plugged- not sure if its normal but the ported side was whistling before i plugged it.
I've tried adjusting the mixture screws and that brought the idle down some, as well as the idle screw on the throttle arm.
its still dieseling something terrible, throwing fuel out once it stops turning over, and it sounds a little uneven.
will it sound different with a different carb on it? What can cause this dieseling issue?
thanks for the help.
