Need wheel ID
tater55tot
Jonathan
I bought a parts truck that came with these 15x10 5 lug wheels. It only came with 3 of them and I’m wanting to find a fourth. I’m having h*ll trying to find the exact model of wheels these are.
The only center cap they came with said Weld Racing. Posted on a weld wheel group and one of the admins says they are not welds. I can’t for the life of me find the exact model. Anyone care to help?
Rusty Nail
Rusty
350sbc
Wow.
Sweet wheels - will be worth the effort imo.
The outside lip looks rounded but the inside is more squared?
I vote Ultra.
Lemme help.
vintage wheel catalogs .com
:waytogo:
*not ultra.
Have fun!
Washington
They look like knockoff Weld Typhoons. But being a multi lug pattern are definitely not Weld.
Unfortunately unless you have reason to believe they’re fairly new, they are most likely discontinued.
tater55tot
Jonathan
Thanks, I figured they were discontinued being that they’re older wheels. I just wanted to see if anyone knew the exact model so I could start looking around for the fourth wheel.
At this point, I’m not too sure whether I should hold on to them and search for the fourth or just let them go.
Do you want to use them because you really like them, or simply because you have them? If it's just because you have them, then let them go. But if you like them, find a match. I bet they will clean up really well.
Could also be Eagle Alloy or Progressive. Have you dismounted a tire from one yet?
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
Secondary pattern doesn't look original, looks like someone had them re-drilled in a different pattern. The larger 5 lug has relief cuts machined into the edge for socket clearance and are recessed a little deeper for more wheel stud engagement on the lug nut.
I suppose they could be centerline
CalSgt
CA
Casey
tater55tot
Jonathan
I like them, but no special attachment to them. I haven’t dismounted a tire yet
tater55tot
Jonathan
I thought I found a centerline that was close but the more I look the more differences I see...
https://offerup.com/item/detail/1340405486
Yea I’ve found plenty of “look alikes” but they’re all just a little different. Makes me wonder how bad it would look with one slightly different wheel
nvrenuf
Mobile, Al.
I could be wrong but those look like Weld Roadhawks.
I have no idea what brand the wheels in the first post are they look like an “inexpensive” copy of the old Weld D7’s.
Flutes are on the wrong side of the windows though.
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
Or you could get 2 new look alike ones, and have them on one side, and have yours on the other. Bet no one would notice.
scrap--metal
MN
Calvin
'85, '81
K10, K20
^^^ That's the ticket if you actually like the wheels. Then your third original wheel can be a "matching" spare.
CalSgt
CA
Casey
My dad tells a joke about one of the guys he worked with drove a truck every day for two years before he noticed the stripe down one side was a different color than the other side... On his own dang truck.
Mistafishe
