Need help with serpentine swap on 1987 R10
Sam01
Oklahoma
Sam
R10
Need some advice on doing a serpentine swap from a 89 Suburban. Were trying to figure out how to mount the power steering pump without using the black plate that connects it to the manifolds. We have already swapped to headers with Stage 8 locking bolts so we really dont want to have to change it now. If anyone knows of a custom bracket or some kind of modification I can do to keep the header bolts please reply.
Sent from my SM-G970U using Tapatalk
RoryH19
Rory
R10 Silverado SWB
I preformed this swap but still have standard exhaust manifolds .
Depending on the size of the header tube, have you tried to notch the bracket? Open the hole a little?
RoryH19
Rory
R10 Silverado SWB
Edit:
I also used the thermostat housing and upper radiator hose from a GMT400 (eg 89 chevy 5.7)
It helps with clearance over the fan shroud.
