Need direction as to where to buy this
Doppleganger
OH-MI: Just like it sounds
I have seen these online but they never mentioned an 85 K20 application and usually said "for disc brakes". All 4 or just the 2 I have? And every one I see is brass....these cast iron?
Either way.....need to know where to get the correct / good brand of these. Saw a couple made in Viet Nam....will pass on those.
Thanks fellas.
C10MixMaster
Kingman AZ
Ben
C10 BIG10
ZZ4 350
Bigjake
Lake lure, nc
GMC Sierra 1500
350 v8
Vietnam is actually far superior than China in most things.Not sure about car parts but we have a vietnamese employee and she fills us in on these things. Flower pots for example, made in Vietnam may be left outside through winter. Chinese pots will break. They hold themselves to a much higher standard. For all its worth.
Those very rarely go bad. I wouldn't be afraid to get a used from one of us and trust it. I assume yours is leaking and why you're replacing it?
Many times guys will think these are bad when they just need a reset. To reset them, you pretty much just bleed your brakes and it will cause the valve to swing and go back to it's happy home by the time you're done. Occasionally they'll get a hung up, but the bleeding brakes usually is enough force to make it move again and it's good for many more years.
Being they rarely go bad is probably why they're hard to find. Discount Auto Parts only like to stock what they can sell a million of every year. These things would sit on their shelves for years and years.
TubeTruck
East TN
Denis
Suburban K10
LQ9
Mine was bad on my '75. I couldn't bleed the rear brakes, and yes, I reset it. I pulled the line to the rear brakes and stuck a paper clip in to push the needle back, let it sit overnight and it never dripped. I had installed a brand new master, which bench bled fine, and all brand new copper/nickel lines so I knew that wasn't the problem. I bought one from carolina classic trucks and that did the same thing. Everything I was reading online said many of the new ones are junk out of the box. I ended up tee-ing the front brakes and installed a Willwood adjustable proportioning valve for the rear and it worked fine.
curbstone mech
westminster md
allen
k20
I just purchased a new bedroom suite and was surprised to see that it was manufactured in Nam.The quality was actually better than I expected
bennlenl
