7900_Blazer
- Jun 15, 2021
- Texas
- Francis
- Blazer
I have a 1985 K20. It appears the previous owner put in a crate 350 - likely the lowest horsepower/torque engine - it doesn't have a ton of guts. A few months ago I swap out the SM 465 for an NV4500. It has an edelbrock cab (unknown which carb).
I'm about to swap out the front clip (rusty fenders - easier to replace than fix); and having easy access to the motor, I thought I'd add something - anything to give the engine a bit more power/torque.
I've considered adding a cam but am unsure which cam to swap in. I don't really have the $'s for heads... unless I can find something 'better' but inexpensive. I've also considered adding a better intake... but unsure.
If you are so inclined, could you provide specifics - exactly which cam you ordered or which intake you've had good experience with etc...?????
Much appreciated.
Much appreciated.
