Mystery trans identity help
78C10BigTen
pennsylvannia
C10 BIG TEN
Im just tossin this out because i dont know wat it is... came into our pile at work. Ive never seen one with that kinda back end.
78C10BigTen
pennsylvannia
C10 BIG TEN
82sbshortbed
Why like that?
SE Texas
Doug
1500 shortbed, 1500 longbed
Try Google the number on it?
MrMarty51
Eastern Montana
Martin
Yup, I believe that back in tje olden days, the 3/4 ton units run with the transmission mounted parking brake and four flange braking drum.
Turbo4whl
Downingtown, PA
Wayne
I am not 100% sure, but I believe that would be for an open drum type brake with the external brake band. Not the shoe in drum type. The system could indeed stop the truck if the single line type, to all wheel master cylinder system failed. One plus was you could replace the band without removing the drive shaft. Disconnect it and spread it open to fit past the drive shaft.
This picture is not the correct band for that unit, but it will give the idea.
Termite_Delight
Lanark Ontario Canada
K2500
5.3 L33, 4l80e, NP241c
The part on the right side with the teeth is where the e brake handle attached.
78C10BigTen
pennsylvannia
C10 BIG TEN
Ahhh ok!!! So im still wondering is it a 465 or... 420?? Or.... not that i care cus its scrap but.
wonone
