My opinion, our fuel tanks rust from the outside because of the plastic cover...
roguewave
Texas Hill Country/South Portland, Maine
Bobert
76,83,84,87,87,88.
4X4
I’ve seen many of the tanks on my trucks rust from the outside because of the plastic shield that covers the bottom and sides of the tank. It traps all kinds of crap (leaves, mud, water) in there and it stays there. The moisture it traps ruins the tanks.
I’m sure y’all know this already but thought I’d say something, it’s just my opinion.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
It’s my opinion as well.
A lot of the things auto manufacturers do today to keep the ride quiet has a huge negative affect on corrosion. The sound deadener injected into the cab corners and rockers are a big sponge, once they get wet they never dry out.
Unfortunately that’s a fact of life. I wonder how well these trucks would have held up if someone took them apart, spray lots of rust proofing and corrosion prevention inside the panels and making sure all the drain holes are clear. I’m sure very few people ever thought of it
I got T boned in my Ram a couple years ago. The body shop had to replace the passenger side bedside. Since I had tiny pinholes bubbling in the bedside over the wheels on both side, I paid the body shop to install a replacement patch panel on the drivers side. Once the bed was cut up, those tiny pinholes that were visible on the outside were massive chunks of rust on the inside.
I had the body shop remove the sound deadener from the bed and rockers and coat the inside with 3M rust preventive spray. I haven’t noticed any more road noise than before.
While I enjoy the snow and snow activities, I envy those of you who live in dry rust free climates. Pretty depressing when a Arizona parts car is in better shape than what we try and fix here in Indiana!
dusterdude
Marine Corps
US
mark
gmc c15
Its a fact,just had my left side tank patched on the bottom
Sent from my LM-X420 using Tapatalk
Rust? What's rust? Arizona baby!!!:favorites37:
Iron oxide, a corrosion that we call rust that uses iron, water, and oxygen. all three must be present for the reaction to occur. Arizona is very very dry, thus water is not just all-time present. Roads also dont need salting or sanding which cling to cars and help the reaction in us northern states.
I know you were just flexing, but here is your overly explained reply to your joke commment hahahahahahaa.....
Hi there.
Paladin
"Teufelshunde"
Wichita Falls, Texas
C30 Silverado Crew Cab Dually
Since it is what it is, how about a little preventive maintenance? Once a year I remove those aforementioned tank shields and make sure there is nothing in there that might cause problems, It's only a few bolts and it can be removed easily without screwing with the tank, on my truck anyway. Problem solved. Doesn,t take long and its much easier and cheaper than replacing or repairing a tank! JM2:cheers:
Odly enough my passenger side tank never rotted out under the shield. It rotted out on the opposite end of the tank. Weird
The Right side of Washington
True story.
My rust free truck, save for A pillars compliments of the aftermarket visor that was on it for....ever, just replaced 1 tank.
Front was rusted out on the bottom due to years of mud packed between plastic guard and tank.
The other side was clean and zero rust.
Paladin hit it on the head. If you go in the mud, clean em out.
Curt
Loco Hills
Curt
K-30
Previous owner of my truck had a leaking heater core.It was still wet when I ripped out the cab floor insulation and vinyl on passenger side.I also live in the dry desert.Unfortunately a rust free truck except for that.Heater cores are a pain on these trucks.
My grand dad’s pickup and anything else driven to the potash mines in the area for work,rusts extremely bad.Salt content on those roads and areas are way high.
Curt
Loco Hills
Curt
K-30
Oh,and I hate mud.It reminds me of power drinking and those bad hangovers.
It’s never worth it the next day no matter how much fun you had.Jmo
RoryH19
Rory
R10 Silverado SWB
True story.
Exactly.
My 87 R10 zero rust anywhere, tanks are great, has a plastic shield on each one.
My 82 k5 has a skid plate and mud caused a few small pin holes. Not an issue since I was changing for a LS swap.
Same thing on my k10. PO must have lived in mud. Can't tell you how many times I had to power washed to remove mud/dirt. I know this is why the tanks are shot. They have the metal shield which I think makes the problem worse than plastic ones.
BigDaddy72
Bentonville Arkansas
Travis
C30 Chassis Cab
Not that anyone has asked but I have a 20 gal tank with sending unit that’s in excellent shape 2-3 years old.
Free. Local pick up only.
Ken B
indiana
ken
I just replaced my tank Not sure if was original since 81 but i coated the tank and straps and think i will let it "air dry" and not put plastic shield back on. Rust made my truck probably 100s of pounds lighter than original
I was debating even putting the guards back on. But honestly, it's a non issue unless one doesn't realize they packed em full of mud or doesn't care.
I saw someone in another thread mention either adjusting them to have a slight downward angle or putting a few holes in them as drainage, but as you say cleaning your vehicle or just showing any care to it would probably fix that problem
Id think the only road debris i would ever worry about is a 4wd that the front wheel might kick something and shoot it back at high velocity, but then that would go for rear wheels on the backside
bajadiver
