Motor ground gets hot
Winchester
George
Morning ya'll. I have a 85 C10 4x4, just put a new long block in. Hooked everything back up and tried to start it. When it turns over the ground strap from the firewall to the right rear of the engine gets hot and smokes. When I unhook the ground strap the starter just clicks. Never had this problem before, obviously something I did but I've traced the wires and can't find a short. Anyone else ever have this problem?
Winchester
George
Yes the ground is clean. I unhooked it, it wasn't hooked up before I did the block swap but it always started. Can't find any frayed or broken wires anywhere. I looked for a couple hours yesterday before I got frustrated and called it a day!
Winchester
George
I didn't think about that ground doing more than it's share of grounding. The battery ground is clean,no corrosion. I'll get back to it as soon as the rain stops, I don't have a shop or garage, doing it like a pine tree pitt crew. Thanks for the advice Ark-N-Saw,I'll let you know what I find!
MrMarty51
Eastern Montana
Martin
Is the battery ground hooked to the frame or is it hooked to the engine ?
I always hook the ground to the engine then, take another grounding wire of the same size and run it to the frame, then, take another wire of the same size and hook it to the body from the frame ground. That way everybody happy. :Caffeine:
Camar068
10 yrs Air Force
I'd replace the positive and negative cables.
same here. I'd do that and change the positive going to the starter just in case.
Dmack
Central OR
Dave
My truck did the same thing. Found that was the only ground from the engine block to the body, which also was the route to the frame as it was the only ground. Starter pulls lots of amps and needs a good, large ground.
I added a large battery ground cable from my frame battery ground to my alternator bracket, giving the system a good ground from the engine directly to the battery ground . No more heat or smoke from that small wire at the back of the cylinder head to the firewall.
Winchester
George
Thanks for the suggestions, I'm going to recheck all grounds and add a couple. I'll let ya'll know if it cranks up,burns up or blows up!
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
I will send good thoughts your way. No burn down or blow up. Lol
Take it from a man who knows about smoking wires...
I don't mean 'smoking' wires... more like wires a smoking... no not standing there with a joint... oh never mind
Arkansas_V8
Proud Redneck
Springdale, Arkansas
Brent
V20 Suburban
That ignition wire fire I had was a pain in my butt. Lol
Termite_Delight
Lanark Ontario Canada
K2500 K2500
350 L33
My truck it did the same thing. Found that was the only ground from the engine block to the body, which also was the route to the frame as it was the only ground. Starter pulls lots of amps and needs a good, large ground.
^^^ What Dmack said ^^^
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Just because the cable “looks” good, doesn’t mean it is. You can have corrosion inside the insulation where you can’t see it. Look on YouTube on the process of performing a voltage drop test. That’s the best and most accurate way to ensure electrical integrity.
Get it fixed, before you let the magic smoke out of the wires. Once the smoke is out, nothing electrical works.
djisurfli
