MagnaFlow vs Flowmaster vs Straight Pipes
Iowan
Loud and Proud American!
Iowa
Calvin
K1500
350 crate
You really don't want to screw around running propane right now. You're new to all this, just run gasoline you can get anywhere.
Oh I know but I've always been curious about this stuff though.
My Grandpa always said you cant learn too much.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Because it holds moisture and wil ulimately Kill the headers.
Ceramic coating is WIN.
GET SUMM.
9.9 times out of 10, 1.5 inch primaries are better for street trucks than 1&5/8”.
Now what?
Half my fleet runs BB so I guess that's 5 times out of 10 for me.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Guy can dream..?
Propane in an 11.1 compression BB sound pretty fricken niiice.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
13:1 or bust
It would work but some fuckerywork to get there I imagine. Can almost never have too
much valve lift either but that might get seriously compromised with the 'super' dome pistons
needed to get over 12:1.
If valve pockets on domed pistons get too deep could this not have detrimental effects somehow?
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
I thought big balls was 13.5?
Am I thinkin 12.5???
I'm pretty sure it was 13.5:1
-and header wrap holds moisture....:deal:
No header wrap except for rust...
Anyway while your here... would the heat continually boil off any moisture, leaving everything popcorn fart dry?
74 Shortbed
Yep, as long as you don't shut it off, that's when **** happens, same as getting an engine up to temp and oil still cold and shut it off, valve covers start to rain. :D
Encinoman45
Ohio
Joe
I have always had good luck with dynomax. Good sound without being overly loud and no drone. Flowmasters cost too much power.
74 Shortbed
Ya. I really like Dynomax mufflers.
I really like Flowmaster too but I don't like 40 series volume anymore. I never heard of a flow "costing power" I think that's laughable.
Delta Flow 50 series.:waytogo:
Moderator
I've run across too many dynomax products that were low quality so I have always tried to avoid them. There's usually something better available for just a few dollars more.
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
GET SUMM.
Now what?
Exactamundo! Wrapping headers traps moisture and quickly rots out the metal. Ceramic coating (jet hot) both inside and out is far better than any wrap.
smoothandlow84
Steve
If you're planning on submerging in the Pennsylvania crud mud, then no matter what you do your headers will rot. Ya better buy in bulk. The clay content will retain the moisture no matter what.
that_orange_c10
