Looking for wheels
Doug80
Chicago
Douglas
I'm having a hard time finding wheels. Looking for 15 8in wide with a 4.5 bs. Anyone know of any sites that have some?
Doug80
Chicago
Douglas
77 K20
Montana
K20 5" lift
HT383 fuel injected
4.75" of backspace means the tire will be .25" closer to the leaf spring than the 4.5" one you were looking for. (it will move the tire inward)
The offset is a different way to calculate backspacing.
At a certain point it can rub on I think the sway bar... maybe someone will chime in here.
Thought more than 4.85" was the limit. More than this causes rubbing...
Doug80
Chicago
Douglas
Dam hmm ok then so 3.75 would be better for no rubbing?
Doug80
Chicago
Douglas
Or a 4in bs?
4 inch is right about stock for a 15 inch wheel. IIRC, much more than that on a 15, you get rubbing on the tie rod.
77 K20
Montana
K20 5" lift
HT383 fuel injected
I'd go with the 4" backspace. I just went out and looked at my truck with the 4.5" backspace, but I have 16" wheels. The tire rod would be very close with a 15" wheel.
What size lift are you putting in? What size tire are you going to be running?
Doug80
Chicago
Douglas
4 in rough country 15 by 8in wheel with 35 by 12.50 rough country says the 15 by 8ij wheel with 4.5 bs is what I need but I have heard some guys running the stock rally wheels and have no issues
Don5
West Virginia
Don
k15
I ran 33 12.50's on stock rally wheels with no problems. I have mounted two sets of Q radial buckshots which are 35.5 inches tall on rally wheels with no problems. The current plan is to run 35 12.50 Cooper Discovery tires mounted on factory rally wheels. I don't think there will be a problem with that combo either.
Doug80
Chicago
Douglas
Those are the tires I want to run to!! Lol do you have a 4in lift? Any rubbing with the tires on the frame or anything?
Don5
West Virginia
Don
k15
No I have a 6 inch lift on my truck. My point is those tires will fit on those rims with no problem. I have had a 6 inch lift on my truck for a long time. I also highly recommend getting a raised steering arm also.
Doug80
Chicago
Douglas
My kit comes with the raised steering arm just gotta get tires now glad to know done need new rims that the old will work also the rally wheels are they the same on a 6 lug Chevy van? Saw one at the y pull it and need a spare tire don't have a rim for it are they the same rims?
77 K20
Montana
K20 5" lift
HT383 fuel injected
I'm pretty sure the van version was only 15x7 instead of 15x8 like the blazers/suburbans/trucks had.
Doug80
Chicago
Douglas
Dam! Lol any idea were I can find a stock rally rim for the 6 lug pickup? Besides lmc?
BESTCHOICE
