Location of cowl drains?
t44e6
NH USA
Assuming on the outer region of the undercowl area, where are they accessed? From underneath? Is there a rubber drain or just a channel between panels? Thanks!
gmbellew
Kansas city
glen
suburban 1500
on my 1990 burb you have to remove a little plastic cover piece behind the fender opening from underneath to access the drains to clean them out. there may also be a little foam piece you have to pull out of the way to reach up and clean them out. I've done mine once and it was a flush, clean, flush, clean process until you don't flush any more stuff out. if you pour some water into the cowl, you ought to be able to figure out where they drain to.
t44e6
NH USA
That will give me something to go on. Thanks!
Auburn, Washington
^Yup what he said. Are yours totally plugged or can you chase the drips?
gmbellew
Kansas city
glen
suburban 1500
once they start to get too plugged up with stuff and drain slow, water will start to come in the cab above the kick panel during heavy rain, or at least that's why I cleaned mine a couple years ago
