LMC hood kink kit - work on an already kinked hood?
Mine was damaged when I got it. It's still damaged but not super noticeably.Iubed up the hinges and took the springs off and made a prop rod no springs stopped the bending.But the SOB is heavy.
gotyourgoat
NRV Virginia
gotyourgoat
smokin' 305
Oh, you think the LMC braces would keep the hood working normally? If so, I think I will do that. I was under the impression from previous posts that the braces still kink with opening and closing.
Well I mean they are sort of a band-aid. It isn't going to fix broken ****, but it can help from making it worse.
You love round eyes. So for example let's just say you have a round eye that has clean fender bottoms and a flat non creased hood without rot in the nose. Great, now let's think about putting some paint or rust prohibitive on the fender and hood innards and bracing the hood crush points.
It is just good preventative maintenance of known issues.
If you already have the issues. Well then it's bend it back straight, brace and reinforce as you can. Making sure all the pivot points are lubed and moving free so you don't make anything any worse. :33:
Already bent metal wants to bend more.
The whole hinge mechanism coupled with the design of the hood is a menace to the hood itself on the round eyes.
80BrownK10
Greenwood, SC
Nate
I have them from LMC. My passenger side has a minor link that raises up a tad. I had the guy that painted it weld the broken torn hood up to help that part strengthen. But I agree there not that strong but I put them as a preventative to keep it from getting worse
What I mean is my hood doesnt match and line up properly, the nose of the hood aggressively shoots in like a back sweep and the rear by the cowl is slightly different, because the hood is from a 77. my 1980 hood swept forward and lined up with the fenders more. The current hood is in excellent shape considering it was laying on wood 4x4s and sat in the weeds for 15 years, but it clashes.
Its not too seriously noticeable, but was hoping to revitalize my original hood. But from what I hear from yall, its pretty toast to not rekink and it would visibly be creased or raised up when lower, most likely. I might just eventually paint the whole truck cheaply to make it match and go from there. I dont think I will ever fully restore this truck, I think i will keep it in running order and a work truck, but the amount of money to dump I dont have excludes hoods lol. At least until the mechanical is all sorted out.
Mikes78K20
SW Warshington
5.7 currently...5.3 future
I installed the LMC kit and lube the hinges every now and then with WD40. It opens and closes very nicely.
Strips of 1/8" flat stock would work. For maximum flex control, do NOT use self tapping screws. Use 1/4" rivets in holes drilled with a good 1/4" drill bit. You don't want any slop in the attaching holes at all.
walt171
