Lh6 swap into 83 C20 Crew Cab
fowjacob
Lubbock,TX
c3500
383 Stroker
Well fellas I'm finally getting started on the swap so he we go. Donor vehicle is a 2006 trailblazer Lt with 5.3 liter vortec lh6 4l60e Trans. Motors going into C20 Crew Cab so should be pretty simple. Gonna try to get a ton of pictures for you guys.
Day-1 teardown
And I few hours later we have the motor out and the harness labeled just to make it easier to go back together
my little helper
I'll have more for yall tomorrow gonna be putting the motor on the stand and getting her cleaned up and looked over. Also probably start on the harness
when putting these aluminum blocks on the stand is it okay to put them on just like the cast one? (sorry never messed with aluminum blocks before)
fowjacob
Lubbock,TX
c3500
383 Stroker
You can just delete this post pictures will explain
350runner
tx
Ceasar
Ouch...
That's ugly. Your mother had to have heard that coming.
firebane
Calgary, AB
Curtis
Is this the motor you were wondering about with the spark plug?
fowjacob
Lubbock,TX
c3500
383 Stroker
Yes sir sure is! Didn't think it was gonna be that bad tho. when I drained the oil straight antifreeze came out! Just got to hot I guess. Mom just said it died I don't know how she didn't hear that
Stewzer55
Ohio
Stew
R30
If you weren't so far away, I might have wanted the rear end out of the donor.
Stewzer55
Ohio
Stew
R30
Ohio, Depends on the ring gear size and ratio, and if it had a G80.
I have the 8.0 and would like the 8.6 with a 3.42 ratio and G80.
fowjacob
Lubbock,TX
c3500
383 Stroker
Just a few miles haha! I have no idea what rear end is underneath it I just have to look
Stewzer55
Ohio
Stew
R30
If its a 8.0 G80 carrier, I'd still want it. Having that would mean my TB won't get stuck as much and would be near unstoppable in the winter. What wheels are on it by chance?
fowjacob
Lubbock,TX
c3500
383 Stroker
These
Wanna saw the exhaust tip off of the rear muffler?
And sell it to me. I have two already, but the end of the tip is cut a little different, and it's obvious when they are side by side. They must differ through the years, if I get a third one, it should match one that I have already. It's for a Camaro exhaust project.
504SquareBody
