tophat36
- Aug 5, 2022
- Bremerton, WA
- Jessica
- C2500
- 350-4 V8
What does that mean? lol
Worth a shot!
Worth a shot!
Yes, no more rag joint and rebuilt boxes are usually not a good bet. Like @Grit dog says if it doesn't feel loose, just seal it. Not sure about the jeep years that work........some body HELP?????Is that conversion where the rag joint goes away completely?
@Edelbrock stated -What does that mean? lol
Worth a shot!
So conveniently I actually had some AT-205 in my garage that I forgot I bought to spray on my suspension parts. Put some in the power steering reservoir with more fluid, which was bone dry again, and sprayed my suspension parts. The crazy squeaking I had is gone and will see if the leak also goes away. Thanks for the help! Seems like everything has leaks…transmission pan and rear differential. This is never endingit is. worst case you still have to replace the seal and/or box in the near future. mine was leaking decent for a couple years. used some of that stuff last fall and it has been dry ever since. someday i am sure it will start leaking again and I'll have to replace something. to me it was worth a couple bucks to see if i could delay the more expensive repair til later.
same with my head gasket. I was burning some coolant on startup, making some white smoke. figured why not try something. worst case is i have to do the major repair that it really needs, and i was pretty sure it wasn't going to destroy some other component. best case is it holds until some other component gives out. some bars HG-1 in the coolant and I am back to just the blue smoke on startup for the last 6 months. I did have to clean out the expansion tank after a while when all the extra stuff accumulated in there. but otherwise I've at least delayed a major repair, but maybe even prevented it until something else major goes wrong with the engine that requires major action.
What about rebuilding it yourself, is that super hard? If there is pitting can it be smoothed out or does it need to be replaced?Mass rebuilt boxes: no good. Professionally rebuilt boxes: very good.
It's worth mentioning that sometimes the input shaft seal will leak because there is pitting on the surface of the shaft.
Idk either but it’s a common part.Yes, no more rag joint and rebuilt boxes are usually not a good bet. Like @Grit dog says if it doesn't feel loose, just seal it. Not sure about the jeep years that work........some body HELP?????
I had no problem:Had a muffler bearing go bad. Could not find a replacement anywhere.
kalecoauto.com
kalecoauto.com
