83Stepper
- Mar 9, 2025
- Massachusetts
- Chad
- C10
Not sure if it's been mentioned, but try inlinetube. Know they do a lot with brake lines and some fuel, trans etc.So far, the only source I have found for a pre-bent steel fuel line is LMC.
They are verifying that their line can be used with my dual tank setup.
Not too expensive itself, but shipping is high.. The longest 3/8" steel tube I have found is 6' and that isn't long enough..... Any suggestions?
But yeah, check rubber hoses first and see if they're leaking and the fuel isn't travelling down the line and collecting there and subsequently dripping.
You can always cut the line, flare both sides and place a union in it. And most reputable local parts stores, not the big box ones, will have lengths longer than 6'.
