Leaf Spring Bushings
matthew101791
Richmond
Matthew
So I'm putting a different set of springs under my truck from a parts truck I had. Problem is the bolts were seized up in the bushings and had to be cut out. I've pressed out the bushings and can easily locate listings for the front forward, but not the front rearward. Also most of the sites aren't very giving on dimensions to compare. Any suggestions would be great! Thanks
matthew101791
Richmond
Matthew
Are these just the bushings themselves, or the outer sleeves as well?
texnet
Ronnie
If you clicked on the link that was provided, then the link on the page http://www.generalspringkc.com/product_p/gmbk-6791.htm it provides a complete description of the parts :)
1967 - 1987 GM 4x4 Front Leaf Spring Bushing Kit
•Includes 2 Bushings and 1 Sleeve
•1 Kit Required Per Leaf Spring Eye
•1 Kit Required Per Frame Eye
•If Ordering 2 Leaf Springs mark 2 for Quantity or 4 if Replacing Frame Bushings as well.
chengny
Here are the parts and components lists:
No part numbers sorry - but at least shows the assembly and part names.
Kipps5000
