Latest Lost Cause Project: 1979 Z28
Midnightmoon
Firefighter EMT/First Responder
Pennsylvania
Justin
Midnightmoon
Pennsylvania
Justin
Side question for you. I took some pics of the rear axle today while I had it in the air. 31 spline 8.5 10-bolt correct? I didn't pull the cover, but by rotating the driveshaft, it appears to be somewhere around a 3.42 ratio which would make sense for an automatic equipped car I suppose.
Moderator
What does the 31 mean on the side of the housing? That's what has me asking the question.
Damned if I know. It's nothing pertinent to the innards of the differential though. I'd assume it only meant something to a foundry worker.
Midnightmoon
Pennsylvania
Justin
I appreciate the amount of accidental learning that happens during a project like this.
77Dmax
vt
Joe
3.42s would be like winning the lotto. In addition to leaving the factory with no horsepower most of those cars got 2.56s, 2.73s and the occasional 3.08s. It was a very dark time...
Moderator
I thought I was lucky with my 3.08 and limited slip. It doesn't matter much though, it's still going to get a 3.90, lol.
Iirc, Z28's all got a 3.73 as standard.
Moderator
The stampings are normally on the forward facing side of the passenger axle tube. They can be a real bear to read if there's any amount of rust. Be careful cleaning it off to read it, as too much cleaning can make the stamping even less defined. A wire brush by hand is the safest way that I've found.
77Dmax
vt
Joe
A quick Google search confirms your are mostly correct. Manual z28s got 3.73s and autos got 3.42s standard. I am shocked GM had that much of a pulse back then!
Midnightmoon
Pennsylvania
Justin
Found G 117 in that area
legopnuematic
Licensed Junk Dealer
MO
Spencer
3.73s in a manual- that would explain why my dad said his neighbor growing up’s 79 Z-28 4 speed felt really quick.
Although, my grandparents at the time had a 1978 Caprice classic, 305 2 barrel and a 1980 Toyota SR5 pickup, so it might not have taken much for something to feel like a rocket.
brooksman9
Olive Branch, MS
Patrick
Silverado & Custom Deluxe
350 & 305
From this post I believe there are some other numbers before that
Another good one
hauto85
