Knocking/ticking noise after oil pan gasket
alwaysbroken
California
Randy
so I have this 77 k10 sm465 it was my grandpas truck before he passed away and Ive be been using it as a daily driver the the past few months but today I noticed my rear main seal leaking so I changed the oil pan gasket. My truck was running and driving completely fine earlier today and then I changed the oil pan gasket and oil filter and all that jazz went to go move her out of the garage and bam!! nothing but damn ticking and it’s a real loud ticking I thought it was lifters but I’m not so sure now if anyone’s got any ideas I’d appreciate it I dont particularly wanna blow up my engine
alwaysbroken
California
Randy
….i am aware it could be the crank bearing or if bolts aren’t tightened all the way it can’t create vacuum for oil pressure but I’m at a loss I’ve gotten every mechanic in the shop I work at to look at her and can’t find where the noise is coming from top or bottom end since it’s so damn loud
What all did you remove to change the oil pan gasket and rear main seal?
alwaysbroken
California
Randy
I only removed the oil pan cleaned the mating surfaces and that was it nothing else was taken off or removed oil pick up is completely clean too prefilled the oil filter also so there should’ve been very little to no air in the system
alwaysbroken
California
Randy
yeah I did I took off the main bearing put in the new main seal torqued em to 70 ftlbs my main bearing did have a few scratches but overall no copper was showing
So in post 4,you only removed the oil pan,in post 7 you also removed at least 1 main cap. What else,I don't care if it is the oil drain plug gasket,what all did you remove? Every single piece you removed.
smallblocksa
