lil catching fox
- Aug 21, 2025
- Kansas
- Tanner
- K10
I have a 1983 K10 shortbed with a 305. The truck originally had a 700R4 but the previous owner swapped it with a TH400 with a conversion kit from advanced adapters I believe. The kit came with a new mount and output shaft among other things.
Recently I decided to pull a 5000lb trailer and smoked the Th400 in it (I have my suspicions that the 400 had problems already and this was the tipping point), fortunately I found what I believe to be a TH475 that came out of a mobile home. My plan is to take the output shaft out of my 400 and put it in the 475 and run the 475. My concern is that with an underpowered engine it’s going to do the same thing. I’ve heard the 475 has lower first and second gear which might help. It does have a deeper pan which will help. What other steps should I take to keep this new transmission from over heating? Auxiliary trans cooler? Eventually I would like to swap the engine for a 350, but unfortunately I can’t make it work right now.
