Just bought a K5, dont know how much lift it has...
Corpse
Toronto, Canada
Ramon
K5 Blazer
6.2 Diesel
Can anyone take a guess? it has 33's on it... ill take measurements, where from? center of the wheel to the fender or from the ground to the fender would be more accurate?
i want to fit 35's on it but im not sure if i need a lift or not.
thanks
Swims350
Logan WV
none
stock no lift.
we had the same setup on our 86.
measures are usually on flat level ground up to the bottom of the fender trim,/right up from the center of the wheel, not th elower portion as in the bottom of the fender.
35's might fit, you got some room, but it's be really close, usually a 4 inch lift and 35's fits really nice, room to flex and such, but looks like with an inch or two you could clear em with what wheels you have now, maybe trim the back of the fender a tad if need be.
4 inch would be a safe bet to clear with no cuts I'd think.
this is a 4 inch with 33's.
stock with 32's.
stock on 33's
Swims is right. That's stock :waytogo: Good lookin' K5 man! :High 5:
Brandon_l1000
Tennessee
Brandon
350/sm465/np205
yea thats stock my truck has 31 on it and i set close to that height.
Swims350
Logan WV
none
x3 on good looking ride man for sure.
Manbearpig
Midland, Tx
Tyler
1500HD Quadrasteer
Great looking truck!
Corpse
Toronto, Canada
Ramon
K5 Blazer
6.2 Diesel
the stock suspension axle over leafs? or leafs over axles? because this one has leaf over axle and shims in the back... is that stock? ill take pic if needed
Spring over axle, with a negative arch spring. It's hard to say about the shims in the back. How thick are they?
87R10_Cruising
