Is this the correct linkage for a TH350 on a 350???
DirtyDYT
Ohio
‘79
Looks like the exact same linkage found on my big block swapped C10.
All my swap needed to play nice with a TH350 was a Trans Dapt #9620 bracket to attach the kickdown cable to the linkage.
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
This is my 350/TH350. Maybe it will help.
73c20jim
Tombstone, AZ
Perfect. Thanks. Is that on your '74?
73c20jim
Tombstone, AZ
By the way, does your accelerator linkage loop around the motor, or does it come straight from the bulkhead?
If from bulkhead is there a little loop before it goes to the carb?
Looks like the correct linkage to me. If it's not, it'll at least work and should work fine.
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
Cable has an S shape from firewall to cable bracket.
My original throttle cable, which had a broken fitting, was a little shorter and did not have any S curve in it to reach the linkage. When I bought a replacement cable it was a little longer and needed the curve in it to fit the space. I don't know if you can still buy a true original length cable.
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
I got a new one from LMC that was about 4" too long. They did not want it returned and refunded my money. So, I still have it in storeroom. You can read about it here if you like.
https://www.gmsquarebody.com/threads/accelerator-cable-replacement.22423/
johnalen76
