Intake manifold install question
84 c10 o skool
Houston, Tex
Steven
383 stroker
Quick question.
Going to drop the motor n a couple of days.
Should I install the manifold since its on the engine stand or should I install it after I drop the motor?
Jus thinking if it will interfere with the chains from the engine hoist and cause problems.
Thanks
Georgeb
Wisconsin
George
K10 Burb Z71
I would install it on the stand. Much easier than hanging over the engine in the truck.
MadOgre
NA
NA
NA
NA
NA
Best to do it on the stand so that you keep any debris and dirt out of the inside of your motor.
MadOgre
NA
NA
NA
NA
NA
Also the stock engine hoist brackets go on top of the intake as well you need the intake installed to use a carb pad bracket to pull the motor.
And it is so much easier to install the intake when its on the stand!
Joe383
Moses Lake
Joseph
It is easer to seal the rear of the intake with it on the stand. I use the intake to hoist the motor. It is way better than putting bolts in the heads.
alwaysbroken
