Intake Manifold Bolt Issue
MadOgre
NA
NA
NA
NA
NA
Awesome idea. Looks cool too!
350runner
tx
Ceasar
@chengny where fix you find those bolts and bit? That is really cool.
chengny
The bolts are available at most any hardware store. Here they are at Lowe's (way too expensive @ $20 /4 - look around):
http://www.lowes.com/pd_162075-3767...lar|1&page=1&facetInfo=Socket|Stainless steel
The short style ball end hex driver was just in my tool box. But if you need to buy one - here's a Gear Wrench version for $10:
http://www.gearwrench.com/sockets-a...80544-3-8-drive-ball-hex-bit-socket-5-16.html
Or an SK for $9:
http://www.toolrage.com/prodview.asp?sku=SKT-45510
I'd take the SK.
Remember, it doesn't have to be a shorty and the long arm versions are way easier to find.
350runner
tx
Ceasar
Thanks bud!
Swims350
Logan WV
none
I got some of those for my monte carlo sway bar from a local mine supply shop.
they work good.
MadOgre
NA
NA
NA
NA
NA
Ya I hate the fact that the bolt kits from the hot rod shop seem like they are a 1/4 inch to short. No room for lock washers. Im sure you could get those in 1/4 inch increments
Swims350
Logan WV
none
I actually bought a set of small head stainless intake bolts from summit they have a 9/16 flange under them but the head size for a wrench or socket is 3/8
firebane
Calgary, AB
Curtis
Here it is before cleanup... From my understanding this is a older generation of the performer.
MadOgre
NA
NA
NA
NA
NA
Looks the same as mine. Should work just fine. You should try brake clean even on just a corner to see if it will shine it up.
firebane
Calgary, AB
Curtis
Same intake gone over with a aluminum wire brush and then painted with my appliance enamel paint.
chengny
That reminds me; there are two bolts (shown below) - out of the 12 used to bolt a stock intake manifold to the cylinder heads - that cannot exceed 1" length.
If a longer bolt is used, the tip will contact the adjacent push rod and bend it - or at least restrict it's motion. Use 1" bolts in these holes (that is; 1 inch as measured from under the shoulder of the bolt head to the tip of the threads):
Note the proximity to the push rods:
I think that 1" is the max for the bolts indicated above and the others can be 1 1/4".
But it may be the case that 1 1/4" bolts are okay for those two - and you can use 1 1/2" for the rest of them. Best to check for yourself and not go by me.
GRat
