Intake help
Square 78
Alabama
Heith
K15
As title says I’m trying to decide on intake. Motor is a 406 with 6 inch rods. Cam .593 intake .593 exhaust with 1.6 rockers 249 duration intake 259 exhaust at .050 108 lobe separation. It’s a solid roller setup. Carb 780 prosystem. Afr 210 eliminators. I have a 3000 stall 3.73 gears with 33 inch tires. Compression is 10.2. I’m looking at doing some trans work and installing a manual valve body also. I’m looking at a victor JR or a Weiand team g. Also have msd pro billet mechanical with a 6 al box. Any help would be appreciated
varmit86
Washington
Mark
C30
Both of those are single plane intakes good for higher RPMs, A dual plane intake is going to give you better drive ability down low. If it is more of a race truck and you are planning on revving it out more often, either of the two will work equally well for you, it also seams this route could use more gear maybe at least 4.10 or more, 33" tire is that a slick or ? sounds tall for a street tire. if you are wanting more of a driver and power down low I would chose a dual plane intake and maybe a little smaller cam.
Preston
Mechanicsville VA
Preston
Gonna be a daily driver? Got pictures? Pulling stumps?
Square 78
Alabama
Heith
K15
It’s a mud toy. So I’m looking for high rpms. Also I was planning on gears a little latter. I’m just trying to get motor together first.
Preston
Mechanicsville VA
Preston
What kind of fuel you planning on using?
Square 78
Alabama
Heith
K15
I’m gonna gear and put 35 boggers later.
Square 78
Alabama
Heith
K15
93 at the least
varmit86
Washington
Mark
C30
Then single plane for sure, either will work great for you.
Preston
Mechanicsville VA
Preston
Gonna be like a rocket, I have several friends getting into the mud racing sport, a lot has changed since the bog races most trucks were on the bottle and didn’t touch the ground huh!!!!:grd:
Square 78
Alabama
Heith
K15
Next question I was gonna have the intake port matched and plenum work done. Is it a benefit or no?
varmit86
Washington
Mark
C30
with 10.2 compression you will not have any problem with fuel, I would run at least premium.
Square 78
Alabama
Heith
K15
I was trying to get to the 500hp mark at the flywheel.
varmit86
Washington
Mark
C30
I would just port match to your heads and intake gaskets.
crowe-t
