Inner rocker panal
marks86
Latham, NY
Mark
12v Cummins
So i replaced my rocker but never even hurd of an inner rocker until recently so I purchased one and I am kind of confused on where it goes
It goes on the inner part of the outer rocker....Does that make sense? You should have seen it when you replaced your outer rocker. If you didn't it may have already rusted off.
Crawl under your cab and on the inner side of your outside rocker should be a fairly straight piece of metal. That's your inner rocker. When I replaced mine I welded my inner rocker to my outer rocker and sealed it all off so junk could not get up into my outer rocker and rust it out again....
marks86
Latham, NY
Mark
12v Cummins
Im pretty sure It must be all rusted because I didnt see it when I looked
If I remember I'll have to take some pics of mine later tonight and post them up here and then you'll know for sure. If you don't have any right now it should make the replacement job very easy :waytogo:
marks86
Latham, NY
Mark
12v Cummins
haha ya I hope so, also there is prob two inchs from the bottom of the seat hump and the begginning of the rocker, and thats all rusted out, what would that be called or is that not even a part
Not sure....do you have a pic of the area so that I could actually see it?
Yah, the inner rocker goes from teh bottom of the floor to the bottom of the outer rocker, should be a flat sheet of metal. MOst of them rust out around my way. I have about 50% of mine left so I am just going to plate right over it.
marks86
Latham, NY
Mark
12v Cummins
I dont my camara just broke up, but Im going to the girls house later, I will take some pictures then
FenderBanger
