- May 26, 2025
- Girard, Ohio
- David
- c10
I've had this happen would crank one second and not the next in park but in neutral it was fine.Agreed, the switch may be out of adjustment.
Also, if an auto trans, the neutral safety switch can cause the same symptoms as a failing ignition switch. Next time it doesn't start, try cranking it with the shifter in neutral instead of park.
Switch may need adjusted or something in the ignition system is being temperamental due to heat buildup or maybe a bad connection somewhere.
I have a toggle switch on my ignition but that's so I can spin it over and only light the MSD box when I want to actually start it. Also have a momentary button wired into the starter wire under the hood so I can bump it over without a helper.As long as the steering wheel unlocks, I would just build your own personal anti theft starting system.
