Ideas for extra ports on primary tank?
sticman
Langley BC Canada
Jason
K10 / V10
350 5.7L TPI
My current solution to add extra ports to the primary fuel tank is to get two npt bungs tig-welded on to the tank.
Anybody done something different for secondary to primary fuel transfer tie in?
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
What's the goal? To fill one tank from the other? What you're going to spend welding pipe couplers into the tank, you can just buy a tank switch, and be done with it.
sticman
Langley BC Canada
Jason
K10 / V10
350 5.7L TPI
My goal is to set up the fuel system to able to push LS fuel pressure for the future.
The factory switcher can be too restrictive on the return side for systems pushing 60 psi plus systems and has always been a reliability issue.
Simplest solution is to go to a single tank but I still have to weld a patch on the box filler hole.
Since I have the tanks already i figured to convert the secondary tank to a transfer tank.
aaron06
