Hydraulic clutch pedal support rods
1975c10
Ma
Anthony
Hello I'm new to square body world and converting a 76 C10 to a hydraulic clutch. I have a pedal assembly off or an 86. Unfortunately it only has one support rod to the clutch master cylinder. I'm sure I can make it but I'm wondering if they are the same length. Or if anyone knows the length of both rods. Or should I just install what I have and measure it up.
Thanks in advance.
Moderator
Iirc, there's two different lengths.
Thanks in advance.
If you already have a manual clutch linkage setup in the truck converting it will be faster and easier than swapping the pedal assembly. @bluex has a nice step by step on doing it.
vr1967
Virgil
k1500
6.2L turbo
The outside brace is pn 15521991.
Though discontinued, they can still be found as I bought a new one recently.
LongBox
