How high does your engine temp get when the air conditioning is on
350runner
tx
Ceasar
Mine gets 210- 220
In 100 degree weather
mtnmankev
Ash Fork, Arizona
Kevin
K10, C20
383 Stroker, 350
My stroker does that on the highway running 60-65 without A/C.
If I never get above 45 it runs at 180 or so.
So I should not plan on putting A/C in that truck.
anubisani
MIAMI, FLORIDA
SEAN
R/V 3500
454 TBI TH400 4:11 gears
Mine gets 210- 220
what I did was wire the electrical fan that came with the truck to kick on with the a/c so it keeps the temp down unless I sit still then it goes to 190* but never gets to 200* anymore.
350runner
tx
Ceasar
That's cool! Thing is I have a trans cooler in the way.so I may try a smaller fan. Hope it doesn't cause problems at hwy speeds
chengny
How about a pusher mounted in the void space behind the grille.
Run the power to the new "condenser cooling fan" through a relay. On the control side, wire the coil in series with the compressor clutch feed.
Whenever the compressor clutch pulls in, the condenser cooling fan kicks in too. Doesn't need to be a big unit, just enough to blow away the BTU's picked up in the evap coil.
That way, the main radiator fan can just take care of the engine coolant.
350runner
tx
Ceasar
THIS^^^ is an awesome idea! I wonder if I can find one at the yard while I'm there... hmmm I wonder what cars if any had push fans in front of the condenser.
chengny
Look for a Saab 9000 - they use that exact set up.
350runner
tx
Ceasar
You the man!
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
GM dustbuster vans had them too and they are powerful. 1990-96 triplets.
My '89 stays at 190 all day long with the A/C on. Except on the anniversary of when I bought her, she decided then to run a little hotter. :/
350runner
tx
Ceasar
Thanks retro! I'll keep an eye OUT :) anyone else?
spartantx117
