How do i find out what my gear ratio is?
MarineGreen
Upstate, SC
Thadd
K1500
Wanting to know what the gear ratio of my differential is in my truck is and how i go about finding it out?
Its a 73 gmc k1500 and it has:
Chevy 350
3 speed Wt306 (SM330)
Np205 With dana 44 in the front and 12 bolt in the rear, And i am currently running 235/75/15 tires.
Help is appreciated!
74 Shortbed
Keith Seymore
Motor City
Keith Seymore
4.3L
Chevy 350
In addition to the above you could also pull the cover and count the teeth on the ring gear and on the pinion (ie, 41 / 11 = 3.73; 41/ 12 = 3.42).
It's a good time to change the fluid in the diff while you are at it.
K
3 speed as in, is/was a 3 on the tree? If so, that's a very neat and unusual trans to have in a 4x4!!!
MarineGreen
Upstate, SC
Thadd
K1500
Yeah, my dad had to replace the column a few years back since it was shot but other then that it shifts like butter. And apparently the transmission is a "rare" beefed up 5 bell housing bolt SM326, I do not know if this is true its only what people told me and what i have read, could anyone shed some light on this?
MarineGreen
Upstate, SC
Thadd
K1500
K
I tried the tape on the wheels and drive shaft and it turned out to be a 3.73, Seems fine but is does rev pretty high on the highway because of the transmission only being 3 speeds.
The fluid was actually replaced a little while back so i think i am good on that, But i get what you are saying.
The 3 speed column shift 4x4's weren't all that common. With the NP205 that sounds like an extremely reliable combo. 3.73's IMO is about the perfect ratio for a half ton and no OD. It's still quite freeway driveable at 65-70mph especially if you had 33in tires. Even 31in isn't to bad.
These are my thoughts exactly. Except I won't say a 3-speed 4x4 is uncommon, I think it's downright rare.
Kipps5000
