High idle when slow driving
bigbluechevy
Pearisburg,Va.
Joey
V30
I am going to be putting a new exhaust on my truck also and was wondering if anyone would give me an idea on the best catalytic converter to use on my truck I would like to have the most free flowing exhaust as I can.Thanks.
350runner
tx
Ceasar
Magnaflow makes some real good cats.
chengny
If I am reading the stats on your truck correctly (1987 V30 with a 454), you don't even need catalytic converters. Your exhaust - as originally from the factory - is sweet.
Just two straight pipes (2 1/2") with a muffler inserted in each run:
BTW- That OEM muffler is getting extremely hard to find.
They are made of highly corrosion resistant steel and will easily last for 20+ years - as is the OEM exhaust piping. Here is what my factory mufflers looked like after 29 years:
They were still good, but I am doing a restore so I replaced them with an NOS set (found one @ $329 and the other one @ $189). Took me a few months of looking around to get those prices.
White Racing has 3 remaining (about $400 each):
MUFFLER EXHAUST
USD $395.68
Add to Cart:
Add to Cart
Part #: 15529620
Shipping Weight: 17.8lbs
3 Units in Stock
Manufactured by: GM
http://www.whiteracingproducts.com/index.php?main_page=product_info&cPath=67348&products_id=1615385
bigbluechevy
Pearisburg,Va.
Joey
V30
I live in Virginia and it has to have a cat.I have been checking out everything and this idling problem is how I found that my cat. was stopped up.What Magnaflow should I be looking for I am looking for the best flow I can get and I am planning on using a Flowmaster 50 series muffler I just want a good sound not to loud but enough to know it is flowing good and get the max pulling power out of it.Thanks.
350runner
tx
Ceasar
nothing special in ordering them long as they fit the pipe in your exhaust system it'll work just fine. putting on a cat of any kind will quite down a exhaust system. ;)
chengny
Oh I see, you've got an "N" engine - never mind.
I run one of these on my truck and it runs fine and passes the sniffer test and is only 40 bucks.
https://www.rockauto.com/catalog/moreinfo.php?pk=1317381&jnid=43&jpid=0
Also be sure to break it in properly!
http://www.rockauto.com/info/EasternCat/Converter Break In flyer.pdf
bigbluechevy
Pearisburg,Va.
Joey
V30
I have still been working on my idle problem and found something today it has the wrong PROM in the computer.Would anyone know where I can get one I have the GM part # to get crossed if needed.Thanks,Joey.
bigbluechevy
Pearisburg,Va.
Joey
V30
I was wondering if anyone has done the test light test on the IAC and how does it work I was wanting to check mine out but I don't know what I am looking for I saw it somewere but it didn't give much info.I also am looking for info on how the AIR system is suppose to work I think mine is not working right its pumping air while idling and cuts off when you give it throttle.Thanks,Joey.
joseph916
